oil pressure
Oil pressure when cold should be around 50psi, It will go down to like 10psi when the car is warmed up and its really hot out.
Underboost, that bad boy will sky rocket upwards of 70psi +. It kind of all just depends on how you step on the gas.
I'm in Texas and mine never reaches below 25psi.
LOL what kind of oil do you use?
like stated above, before reaching correct operating temp it should idle about 50psi. When the vehicle is completly warmed up you most likely will idle between 10-16psi in warm weather. Interstate cruising W/O boosting will set u at about 50-55 psi. running boost will always raise your oil pressure at WOT. Do you have a catch can or RRE crankcase breather?
DSMcrazy3 said:
I use Castrol 10w-30. It's always been that way.
HMM? don't know, but we both know that the little extra oil pressure you get won't hurt anything thats for sure.;)
I've always used Discount brand 10W-30, and my hot idle oil pressure was always 24-25psi. After I rebuilt though, it seems to have gone down to 12-20psi. I'm not sure why, though...
im rebuilt with only 10k on the motor. of course the oil pumps new and i use
mobil 1 10w-30 full synthetic. it idles between 10-15.
cyrez187 said:
hey what u guys think about oil catch cans. are they worth getting?
Only if you set it up correctly, otherwise you'll just mess with your vaccume.
P.S. save your money when buying that greddy oil catch can, the white/clear hoses pretty much dissenagrate when they touch anything hot, leaving you with a nice vac leak. Stick with some thick black hoses, and maybe get a oil catch can from jegs or something. They usually come with a little nipple on the bottom so if you place it right you can just drain it during an oil change instead of having to remove it everytime.
Mine is a remote location under the passenger side headlight/bumper area.
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
