Oil pressure reading high
> 100 PSI oil pressure IS high. Get a REAL gauge installed and see what it's ACTUALLY doing.
I assume after the oil light flashed you stopped immediately and checked your oil level?
I agree with My98GSX my fresh built engine is seeing around 80psi when driving and when your pulling hard its over 100 psi. my guage is tapped at the bottom of the engine, so would be less at the top of the engine. not sure how much though
Yes I stop and checked and the oil level was right.
But now the light went away And the issue is the needle,
I'm try to explain, there's 3 levels on the oil pressure guage bottom, middle, top. So when I pull hard at full boost the needle pass the top level,
Use 10-30 or 5-30 is more thinner and can help alot.
You should check your relieve valve it can be bad maybe it got stock and is not opening.
Where is the relieve valve?
