tlcoolj
- 119
- 14
- Mar 1, 2004
Baton rouge,
Louisiana
I just swapped my 7 bolt for a 6bolt and since the swap was done my stock oil pressure gauge has been low. Now i replaced every gasket and seal in the engine prior to putting it back in, no oil leaks at all. The only thing i can think of is i reused the 1g oil pressure sensors on the oil pump. Are these sensors the same or different from the 2g? They looked the same thats why i kept them in but is it possible that they are not compatible with the 2g ecu/gauge?? If thats not the problem then i have absolutely no idea why my oil pressure is low.. any help?
