Oil Pressure Guage
98dsm31710
58
3
Nov 6, 2012
Ravenswood, West Virginia
I've been looking around for an answer but nothing has came up. I want to get an oil pressure guage since ours aren't very accurate. Looking for an electronic one that simply screws into the OFH, run the wires and call it a day.
What exactly is the question? Anyway, all electric oil pressure gauges will have a sender. However, as mentioned above, you should remote mount it. I had an SPI gauge years ago and mounted the sender directly on the oil filter housing. It rattled apart (literally) in a few months. VDO makes a good inexpensive gauge, but your options are basically limited by whatever your budget is.
I went to summit and got the Autometer Electronic oil pressure gauge and then ordered ExtremePsi remote mounting kit.
Gauge Here:
http://www.summitracing.com/parts/atm-6927/overview/
Remote mounting kit here:
EXTREME PSI : Your #1 Source for In Stock Performance Parts
Just get both, you will thank us and yourself down the road. The sending unit that comes with the gauge will last a hell of a lot longer.
Autometer is not always the most accurate
Proof? Info? Any data?
Old shot, but should get the point across:
So much braided line :)
I appreciate all the response. I wasn't aware of the remote mounting kit. Thanks again guys.
