oil pan ARP bolts
Here's where you can get ARP bolts. They're not in a kit, but they're the right thread pitch for the oil pan. You'll just have to make sure to get the right lengths to account for the 2 shorter bolts near the front case.
Hillco Fastener Warehouse
And here's ARP flywheel bolts. Keep in mind these are longer than OEM bolts and are usually only used with an A/T spacer. If you use these, you should run a bottoming tap through the holes to create more threads so the bolts have plenty of space to seat.
EXTREME PSI : Your #1 Source for In Stock Performance Parts - ARP Pro-Series Flywheel Bolt Kit (8-pieces): Mitsubishi Eclipse 90-99
