oil line leak
munk
161
Mar 3, 2008
vassaboro, Maine
so yesterday i got to work and my car had oil ruining outta the bumper i was like wtf well i was able to get the car home and found that i had a leak in my oil line i went to the parts store and vip and auto zone told me they have no part to fix my issue. so is there any where i can order this part from or any way to fix it. i have electric tape and duck tape then a hose clamp over the leak now but its just a bandage.
The dealership would be your best bet if you can't get it from the local auto-parts store.
Wow that looks like it is going to cause a restriction when you bend it...
Why don't you return that and just buy the oil feed line kit from one of the above links i posted ?
It's ok to drive the car like that but be careful and always check your oil level at all times. Don't forget your turbo will fry most likely with time like this.
so its gonna take about 2 weeks to get the part i need a quick temp fix for my issue at hand because i cant keep leaking out 1 quart of oil every 10 miles and about 1/4th is hitting the exhaust im not gonna let my car burn up. what do i need to buy some jb weld and a small peace of 1/4th in hose cut the line and jb weld and clamp the peace of hose on the line? from the section i would cut out. i need a working car
Get that line replaced ASAP with one of the SS feedline kits from the links above. Mine cracked while I was driving, and I lost two quarts of oil. My turbo died a few months later, and I'm pretty sure that was the cause.
DO NOT DELAY ON THIS!!!!
