Midnightride
- 183
- 0
- Oct 4, 2006
Columbus,
Ohio
2G TSI AWD automatic
ok just wanna throw this out there and get opinions:
Leak is coming from where the scatter shield is. I replaced the oil pan gasket dried everything off and its still coming from the same area. Besides the rear main seal, where else could it be leaking from?
It not coming from the top of the block or side. Not from the oil return line either, and not from the oil pan.
I had a really bad PCV valve, replaced it with a evo on and now it will only leak after boosting and slowly not like before.
I have it a shop right now and just in case they come back and say well we replaced it but its still leaking, just wanted to see what else in that area could be leaking oil.
It leaks around from the scatter shield area onto the transfercase.
