oil feed/ reture line??
13guest13
61
Nov 9, 2009
monrovia, California
hey guys just a quick question.. i am about to turbo my car. i have everything already set. i just want ## guys opinion on the oil lines....they have some on ebay. should i get one from there???or make my own from like home depot? if anyone know what fittings i need that would help ALOT!! thanks guys.. i cant wait to get this all together:D
I agree with LiquidX. I went with Extrempsi's oil drain kit though and STM oil feed
The only thing I can think of for you is that you'll need to make a hole in your oil pan which it would be better to get a welded fitting down there. Other than that it should. If you are wondering about it contact the vendor and listen to what they have to say. They will tell you for sure on what you would need to make it work.
yeah i have to make a hole but im unsure about the feed line. and which oil sensor to get it from
you can drill and tap the oil pan but u have to take it off or ull get metal in there and thats not good they sell the t3t4 fitting on ebay in fact i got the dran and feed line but its for a t3t4 to a 4g63 i dont know if that oil pan will work but if it dose u can get a 4g63 pan and use the set up i got
and do you know whats the compresson on these pistons?
ok your going to have to look for a post on 420a oil feed the ull know what u need
I counted my fittings all together about 3 months ago and I think I was up to around 36.. ALL FROM extremepsi and summit..
I made oil supply/return ss braided and water supply and return ss braided... it was a bit of a pain to make water return LOL but all in all once its done right it won't leak
just so you get the idea
Actually you will find about half of the parts you need at Home Depot/Lowes...
Post #6:
http://www.dsmtuners.com/forums/art...uild-420a-stage-2-turbo-kit-under-1000-a.html
That will cover the feed line from the back of your block. You just need a -4an braided hose to go to your turbo, where you will need one of these-
gt30 gt35 gt32 t3 Turbo 4AN Oil Feed restrictor Adapter: eBay Motors (item 120561267956 end time May-24-10 11:45:25 PDT)
You may or may not need a restrictor, depending on the turbo...Most journal T3/T4's don't require one.
For the return you can go braided with AN fittings if you like, but it's not pressurized like the feed. So you can get one of these for the turbo side-
JDM T3 T4 TURBO BILLET OIL DRAIN RETURN FLANGE ADAPTER: eBay Motors (item 270581207413 end time May-25-10 23:06:07 PDT)
Then a proper sized nipple from Home Depot and weld it into your oil pan.
