Oil Catch Can Hose Size Question
DSMorBust
Jan 25, 2007
las vegas, Nevada
Buying an oil catch can and there are two hose sizes to choose from 9mm/15mm. witch one should i be buying? again this is fora 1g DSM the hose to the crankcase to the intake ... just so were clear.:thumb:
Thanks
I'm looking at a chunk of 10mm silicone hose in my hand and it looks fairly big, so most likely you'd be good with 9mm. Best bet would be to measure it or size it yourslef to make sure it'd work on your crankase nipples.
