OFH ??? NEED HELP! thanks
streetsoldier60
55
Feb 16, 2008
Celina, Ohio
I'm sure this has been talked about and I've tried to do some research but am still stuck.
I am putting a 6 bolt in a 2g. obviously like title says but my OFH hoses where do they go?
I have one coming out the top of my E316g turbo and then I have a metal pipe going down to the OFH. but then i have the other hose where should I route this one?
so i have from the water pipe to the turbo then the outlet of the turbo down to the OFH then from the housing to where??? all other lines are run so i'm kinda stuck thanks in advance to any help!
Make sure you have a 91+ front water pipe for the 6 bolt. The top coolent line from the OFH goes up to the front coolent pipe and the other line goes to a small hard line and 'snakes' up the front of the block to the Thermostat housing.
hmm thanks I'll look into that and make sure. but thats for tomorrow I need to get some sleep now. thanks again.
