2G OEM wheel bearing manufacturer
I can get it for you tomorroe if someone dont get it sooner, i have bearings at work, i know it starts with DAC and it does not result in anything as i searched before for research. Koyo makes the oem bearings though
Why do you need this number btw?
Thanks for the help. I’d like to know if there are internal dimensional differences between the aftermarket bearings and oem.
The many i have taken apart no, they all based around the same specs since there is not alot of ability to alter it. The difference will be finished quality on surfaces, clearance specs (likely as close to oem) and ball bearing finishing
The dimension I am interested in is ball bearing diameter which I believe may be slightly smaller on an oem bearing in comparison to aftermarket.
Everyone i have looked at are all 1/2" balls or 12.7mm, for the fronts anyway, i have not looked at the rears in detail.
I have taken apart many units and alot are pattern parts / aftermarket versions and all have the same sized ball and race as oem. I have not opened every brand of course but thus far i have not seen any difference in ball size alone
Thank you for the help Bobby. Are those actual checked values or estimates?
Actual checked with a digital calipe.
Just one of the many bearings i collect. Some oem and some aftermarket and so far bearing size has not altered, but as i said i have not opened every brand.
