obd2 install
coltkelz
78
Dec 8, 2010
winnipeg, MB, Canada
doesn anyone know how to install an obd 2 port into a 93 dodge colt with the 1g talon tsi awd motor in it? anyone know the pinout to the obd plug? where the plug connects to in the 1g?
The ecu won't work with an obd2 plug. And even if you made it pin correctly, any program probably isn't going to be able to utilize it.
Either way though..here is the pinoutclick
What protocol does the 1g use, or what are you planning to make it use. Good luck with whatever it is your doing.
