o2 sensor
onthemountain11
Mar 9, 2010
WDM, Iowa
shop said my o2 sensors or crappin out on my 2000 eclipse gs.. how hard would it be to fix it myself? how much would they cost? thanks
All oxygen sensors are the same as long as they have the same threads and amount of wirs. ebay is your best bet for universal 4 wire o2 sensors. but if you have a junkyard you can get them for free most times. just make sure you seal your wires up real good so they dont short out. don't wate your time with the socket use a wrench to remove the old ons after you heat them up with a torch.
Yeah they're easy to remove and I borrowed the o2 socket from autozone but then found out could have done it with a wrench. Bought mine at oxygensensors.com for $50 and might be able to buy a universal one even cheaper on ebay like mentioned.
