O2 sensor wiring
Pin 4 on the harness side is a black wire. Whether that is what you are referring to or not, both black wires on the harness side go to ground.
http://www.dsmtuners.com/forums/articles-electrical-wiring/244376-oxygen-sensor-wiring.html
I'm talking about pin 4 at the ecu plug its a white wire then connects to a black that I dont know what it goes to. I posted a pic theres that white wire that comes from the big ecu plug then goes into another white wire and a black wire the black wire I am unsure of.
Ah, gotcha. That wire is for the O2 sensor check connector in the passenger side outer kick panel, C-56 here: http://www.dsmtuners.com/forums/articles-electrical-wiring/412841-1990-engine-control-wiring-harness.html. It is an open connection not normally hooked up to anything.
The white wires going into that bundle you have pictured are meant to be the same wire. One end to the O2 sensor and, as you said, one end to the ECU. The bundle is a means of joining those two together from the factory while also tying in the wire for the check connector.
Ohh ok I see thank you so much!
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
