o2 sensor, what wires are what
90CherryTSI
Banned Member
420
5
Jan 24, 2004
Austin, Texas
which wires are what? ground, signal, heating element? On the 4 wire...which one do you tap for the o2 signal wire? i have the haynes but it doesn't show which wire is which. Thanks!
there are 4 wires
1 is ground (black)
1 is ecu ( tap this one that is the odd ball
2 are heaters (same colors )
But you may as well go into the passenger side kick panel and in the harness there is a female plug end all by itself that you can plug into to get the o2 signal.
