o2 sensor question
As long as the threads and the wirs are the same . the only difference may be the plug and you can swap that.
If you are going by dealer part numbers, they are different, but the o2 is exactly the same. Both are 4 wire heated o2s. Just check your plugs to make sure they match on both cars. But, they are the same.
