2Quick4You
- 0
- Mar 8, 2004
Sanford,
North Carolina
I know this is a well talked about subject here and maybe im just not understanding but can someone explain the procedure of porting the wastegate and O2 housing .... My question is " when you port the wastegate bigger and the walls of the wastegate are you supposed to match the O2 housing port to the exact same size and also do you trim the gasket thats between to match the porting of the wastegate and O2 ... I havent seen anything related to trimming any gaskets and was wondering if i missed something ... or is there another gasket you should get and gasket match to that ??? and one more thing when you are porting the turbo inlet do you open the actuall opening that is directly above the fins or just open the intake that leads into the turbine .thanks for your help ...
