Turbo to O2 Housing Gasket Question
4G63Boosted
117
5
Jan 10, 2006
Lynchburg, Virginia
Does anybody know what size turbine outlet the Evo VIII has? I need a gasket for the O2 housing but it needs to have a 2.5" opening for the turbine outlet. I was thinking just for ease and availability, if the Evo VIII is large enough just getting one from the dealer. The reason being that I need it pretty quick, mine cracked between the wastegate and turbine outlet, giving me a pretty big exhaust leak.
On a side not, it seems there are seperate gaskets for the 1G, 2G and evo3 O2 housings. Can the evo3 gasket be used with a 1g O2 housing? Reason I'm asking is that I have ported my 1G housing out significantly. The internal volume may not quite be where the evo3 is but the openings are certainly close. The bolt pattern should be the same, my concern is the layout of the flange.
  • Wanted 6 bolt NT water pipe
    • chrisman287
