1G NT thermostat housing
lowell
320
21
Apr 6, 2006
vancouver, BC, Canada
Not sure if this is 'custom fabrication' enough... just drill and tap work.
NT thermostat housing, bead blasted and painted. Sensors relocated to the rear, ECU coolant temp needs a 3/8 female x 1/4 male adapter to keep the heater core connection. Thanks to EclipseOwner95 for the idea.
http://www.dsmtuners.com/forums/dsm...ucked-everything-hta68-n20.html#post152837755
Not bad. I just welded mine as well.
You should be able to do something similar for a 2G, but the only 2G here right now has a 6 bolt already.
Swirl pot installed
Separates any air bubbles in the coolant stream via centrifugal force and gravity. The offset inlet/outlet will spin the coolant.
It shouldn't have bubbles if you bleed it properly so what other purpose does it do?
You will get tiny air bubbles even if it is flushed properly and you can get steam bubbles forming as well. Most new road race cars seem to have swirl pots.
Header tank finished. 3.5" x 10", 25psi cap.
