Please Support Rix Racing
Autocross Build Part time DD, autocross, and lapping day
Ownership Status
Currently Own
Eagle Talon TSi
Turbo Type
GT30 Variant
Build Type
  1. Street
  2. Autocross
  3. Road Course
FP3052, 950 cc/min injectors, Denso "Supra" fuel pump, two stage water/methanol injection, Kinetic FMIC, 1990 oil filter housing, external oil cooler, 2.5" IC short route IC piping, RSR exhaust
Mods-Engine
2.4L, Crower rods, Weisco 9:1 pistons, mildly ported 2G head, FP2 cams, adjustable cam gears, Kiggly HLA regulator, Kiggly 6-bolt crank position sensor, Moroso oil pan
Mods-EMS & Logging
ECMLink, RaceCapture Pro, Innovate LC-1, Greddy EGT, 150 PSI oil pressure sender, 100 PSI fuel pressure sender, oil temp gauge, boost gauge,
Mods-Drivetrain
Quaife front differential, Southbend clutch, X-ACT flywheel, GVR4 1st gear, 4 spider diff
DG" style Koni coil-overs (950/375 springs), spherical bearing lower control arms, RRE upper and lower brace, custom front upper control arms, front RM sway bar, BAER 13" brakes
Parts Wishlist
Install rear EVO-8 clutch type diff, 6 piston Brembo brakes, EVO rear brakes, brake ducting and ignition system. Need to purchase FP cast O2 housing and larger radiator.
Background
Goal was a low 11 second car that hold it's own in SM autocross, perform even better at a lapping day, and still be very street friendly.
Dyno HP
433 whp
352 lb/ft
Dyno Type
Mustang Dyno
Dyno Shop Name
Racing Greet
Dyno Session Details
24 PSI boost, methanol injection on 94 octane. (Ignition limited, and not DynoJet corrected.)
Videos
T2Small
More in 2G DSM
Share this Vehicle
