nt 2.3 stroker ballancing bottom end
zkheasley
69
13
Jan 25, 2014
marietta, Ohio
Ok guys I'm looking for someone thats had a rotating assembly balanced, I've had this thing together once and made 10 laps before it got hot. When it goes in this time I want everything perfect! I have a OEM 100mm crank, eagle h beam rods and JP 2.3 pistons. My question is what does a shop do to balance the bottom end? Im running a aluminum flywheel and crank pully,and deleted the balance shafts, I'll be hitting the chip quite often and itsa no brainer I should be doing something to balance things out but what's your opinions on what should be done?
