Not enough fuel??? maybe help plz
DSM-T27
Apr 6, 2005
Miami, Florida
Hey another question. My car kind of chokes a lil at higher rpm's could this be the fuel pump, downpipe, maf (highly doubt it sence its new), stock bov, or the intake filter sence i have a 3 inch inlet. My mods are aftermarket B.G. 3 inch exhaust all the way back no cat, apexi 3 inch exhaust the real apexi LOL um thats it for now. Can someone help me thanks. :dsm: :dsm: :dsm:
I know as silly as this sounds but i would check the plugs to see if its causing a misfire, replace them see what happens if not you've spent 6 bucks and youve got new plugs. And don't buy Platnium plugs that some idiots like to "reccomend" at local parts stores. Just an idea. If its a fuel problem, I dont see why you wouldnt have enough fuel considering your pretty much stock unless your over boosting a bigger turbo? :confused: If you feel its a fuel problem replace the fuel filter.... Good luck man, maybe some one else can help out, but we really need to know more than "it chokes" - Tony :dsm:
Just like we discussed in your other thread, your stock bov is a huge boost leak since you hooked up the mbc and boosting 14 psi. After you bolt on the 1g bov, make sure you perform a REAL leak test before you do wot runs.
