to much air not enough fuel???PLEASE HELP
tony_tsi
61
Jun 18, 2007
Cavecity, Kentucky
I have a 95 eagle talon. i have a ported and polished frank 5 turbo front mount ic with all 2.5 piping slowboy ported exhaust manifold i removed the cat and replaced it with a straight pipe i removed the ice box and put a filter in its place. the only fuel mod i have is a walrbo 195 fuel pump. Is this a big problem will this make me run lean. I have a narrow band gauge and an egt gauge. what should i watch for on these gauges. i am afraid to start my car without knowing what to watch for.
p.s. I will be getting dsmlink, aem wide band and 1000 cc injectors in three months i know things will be much better then. hoping for 400 hp
Well the narrow band gauges don't really tell you anything. The EGT's seem to vary in opinion a lot, but cruising I believe it should be 1200-1300º, WOT should be about 1500-1600.
do you think i am safe to drive it and hit 15 psi the new turbo is quite larger than stock
For comparison purposes.
My stock injectors ran 85% duty cycle at 14-15psi on a 16G. Therefore on your turbo at 15 psi I would say no, not safe. Maybe about 10 psi. I also had a 255LPH pump, something to take into consideration as well.
I have a gready profect b at the house what if i put it on and ran 8 psi is that safe will at least have as much power as stock turbo with stock boost.
You "SHOULD" be safe at 8 PSI, however the only way to really tell is a data logger to be able to monitor your Injector Duty Cycle/knock, etc. But 8 psi is definitely much more possible than 15psi in your setup.
cant wait for my dsm link life will be so much less stressfull
Dose anyone have any links to tuning information for a gready profect b? There are many settings such as gain set gain and other settings that i do not fully understand.
So I heard, I'm ordering mine my next paycheck.
Hey come to think of it i have an aem trueboost and a gready profect b witch do you think would be better and easier to work with?
I am doing an h22 swap for a friend with a civic he is going to buy me dsm link seems like a good deal to me!!!
Ha, good deal man. :)
I personally love the AEM TRU BOOST, that's what I use on my car. So simple to use it's not even funny!
I gotta go i will check back tomorrow it would be nice if anyone could send me a link with some tuning info for a gready profect b.
well the prolbem with the aem true boost is that i would have to use the solenoid from the gready profect b are these two compatible?
That I am not sure bro, and I don't have experience with the Profec B neither. Sorry I can't help you there bro.
Depending on the civic your friend has you could be cutting out some parts on the firewall. I know a friend that had a h22 swap and had to tunnel out the shifter bars. It was really difficult for him to do and h22 are so expensive to replace when they blow!
