Non-turbo And Turbo Cranks Different????
AWDphantomTSI
54
Apr 5, 2004
Allentown, Pennsylvania
Alright.....i was doing a headgasket on my gf's 91 fwd turbo and went to change the rod bearings as well.....when i went to take the rod caps off i noticed the rods had TONS of play...like 1/8th inch side to side. Then i looked more into it....and they are NON turbo rods and pistons!!!!! Now i set the non turbo rod/piston next to a turbo one...and the turbo rod is wide enough to remove the play in the crank. My question is....is there a difference between a non turbo and turbo crank....and another quik question...are 90 rods bigger then 91 and + or do all 1g's have the big rods....PLEASE HELP!!!!
I would have to say that 90-92 n/t and turbo cranks and rods are all the same. I know this because I have a n/t crank in my car.
you should have some play left to right because oil floats the rod when there's pressure.
however your rods should NOT move in the other direction... if they do, the bearings are effed
Its alot more than it should be.....just about 1/8th inch....someone messed around with the motor before.....im thinkin maybe they put hyundai 1.8 or 1.6 rods/pistons??? if the non turbo and turbo rods are the same then i have no idea what these are.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
