2G Non-ABS Proportioning Valve?
boostjunkie02
70
May 11, 2004
louisville, Kentucky
I am converting my 95 Eclipse GSX into a non- abs car.
I know they're out there but where can I find a non-abs awd 2g? I need the proportioning valve. Would one work off of any non-abs 2g?
Any will work as long as it comes from a 4 wheel disc car. That means gs with rr disc, gst, and gsx. Im not sure if the proportion is the same from the gsx and lower level dsm's. The ration might be slightly different due to the gsx having larger front brakes and dual piston calipers. If it is, it probably wont be enough to notice.
