non 90' oil filter housing idea
stace
86
16
May 27, 2008
Belleville, ON, Canada
OK, Before any one says "just go buy a 90 OFH..." YA YA if it comes to that, then sure I will but thats not the answer I'm looking for.
Before I go out and spent $30 plus on a 90 OFH, hear me out..
Adding a external oil cooler to a 92 OFH:
I took out 2 plugs and replaced them with hose adapters..as you see in the pic..
now If I were to plug the path from one adqapter to the other, it would stop the oil from going to the oil filter, and shoot it straight down into a hose to the cooler. Then after the cooler, the oil would enter the OFH via the other adapter and go straight into the oil filter....
The square would be the plug..wich could be be tapped and threaded for a 1 inch stud or something to block the oil.
I know this would work..as far as oil moovement, but what about the thermostat? would there be a problem running a full time cooler?
(..that's what us '90 owners do have ... is the external oil coolers that is mounted to the lower right and in front of the radiator and not that goofball water cooled oil cooler units. Don't know why Mitz took away that was a good system and went with this compound idea..)
I wouldn't worry about the T-stat section if you can make a good bypass for the coolant to keep that fluid in the loop. If you can get that oil cooler in decent airflow, you should be okey. But, you can add a fan behind that cooler (find you a 4inch, 12v muffin fan if your cooler is about that size) if you have doubts of coking the oil up.
-DSM
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
