noise
Status
Not open for further replies.
Hooah
302
Feb 10, 2003
Olathe, Kansas
weird noise comeing from back part of engine. sounds like a electical spark kinda speeds up as you rev. just started and is getting louder any ideas?
did u check ur spark plug wires? i had the same noise an my plug came disconnected at the intake mani an was sparking toward the wire
i looked at all the spark plugs wires and all are on tight. i also looked at the motor in the dark while it was running and i couldnt see any sparks and like before im still clue less. any more ideas
Did you figure out the problem? I am having the same problem and am having a hell of a time searching for this.
Try replacing the coilpacks there ae 2 side by side.
Don't recommend someone to replace a part to try and fix a problem without first testing anything.
Post a video, it is 100 percent impossible to diagnose a noise without at least hearing it.
Status
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
