noise coming from passenger front wheel
eclipsemaniac
46
Jan 15, 2012
weaverville, North Carolina
I checked to make sure rim is tight. When I drive there is a terrible rubbing noise coming from the front passengerside of the car. There is a slight play in the wheel but I think its the tie rod end. But the noise sounds terrible I took a video while I was driving down the road about 45 mph I'm in neutral so you can hear the noise without motor or exhaust sound effecting it. please help thanks guys.
2013-03-19_20-46-02_166[1] - YouTube
Do you think it could be a wheel bearing?
Please help
the wheel bearing on the front passengerside was bad. So i bought a new wheel hub with bearing installed replaces good as new now.
No the axle came out easy. Had a hard time getting the old hub out. I used a hammer and chizel to get it out.
