No stock Oil Sender on OFH
P3Kans DSM
286
Aug 4, 2010
The Harbor, Illinois
Okay I've searched and searched but can't seem to find the answer to my problem... Well problems. First is my OFH. I don't seem to have a Oil Pressure sender. WTF don't ask me I've looked for it, looked on here can't find it. So I got an Oil Psi gauge so where do I put it. Would it be in the Allen style plug in the front?
Next I bought some injectors from a fellow member and I'm tryna figure out how the seals go. I've included a picture of how I think they'd go and what the objectors and seals actually look like.
Thanks for any help its greatly appreciated.
That looks to be a 90 ofh, but it doesn't have the hole for the sending unit. IT should be on the bottom between the 2 rear bolts on the housing. You could also drill the housing and tap it for a npt fitting where the sending unit should be.
You can see in this link where the sending unit should be.
That OFC probly came off a pre 91 JDM galant vr4 , they only have an Oil pressure dummy light and no inaccurate electrical gauge, and it still had extrenal oil cooler taps.
Makes sense. Motor came out of a VR4. I Looked all over here and the vr4 website for differences but came up empty. Thanks I already got my 3/8 to 1/8 reducer on the way so ill run it from the Allen bolt.
    • george bromwell
    • pma1123
    • Sdcryan1
