No Starter plate = Cooler flywheel?
4g63telantra
454
Dec 10, 2004
Toronto,
The starter plate im talking about is the one between the tranny and motor. It has a hole for the starter.
Well I need to get one for my FWD Tranny/Turbo motor to be safe.
But...
From what I hear without one will keep your flywheel cooler or do I really need to use one?
Well that depends, do you want to take the risk of having debris get in there when you're spinning that thing at 6-7k rpms and having that debris go flying around inside the bell housing or even flying THROUGH the bell housing? :barf:
As you can probably guess, I'd say leave it on. Not worth taking those kinds of chances for a slightly cooler flywheel (with a good clutch that shouldn't matter anyway.)
Hey Guys.... I got my rebuilt motor and tranny all assembled and bolted in place tonight and realized i left that starter plate off between the motor and the transmission.... Will my car be fine 2 run without it? also I will be putting the lower one on as that covers the bottom side from debris.. Let me know guys. Thanks, Larry
