NO START... injectors?
91eclipseGS313
Nov 12, 2006
detroit, Michigan
my engine wont start unless i spray starter fuild in the throttle body... im getting fuel pressure to the fuel filter and my fuses aint blown... i also ran it in diag. mode to see if the ecm was fryed but im gettin a normal code reading... does this mean its the injector?... what sensors would kill my injectors?... where should i start my diag.?
i feel sick without ellie :barf:
help me out homies :dsm:
Has the car been sitting for some time? We had the same problem on a freebie car we got from a guy. It had sat for some time and it wouldn't run unless we sprayed starting fluid into the throttle body. The fuel pump was shot, for what reason I don't know. We pulled the pump out and tried to run it directly off a car battery and it didn't work. So we threw another pump in and it fired right up. So if your not getting fuel pressure I would check to see that your pump is in working condition.
Getting some fuel pressure and getting proper fuel pressure are two different things. My suggestion. Check to make sure that the injectors are being commanded on. If so, then check fuel pressure with A GAUGE.
Do you honestly believe that all four of your injectors went bad at exactly the same time? I hope not. There are a ton of things that can stop your car from running, including a bad or disconnected coolant temp sensor. Check voltage at the injectors first and we will go from there.
