trouble with fuel injectors! no start
sacline
70
Oct 6, 2012
new richmond, Wisconsin
Its a 1990 tsi. The original injectors were the blue top....i received black top ones from injector warehouse.com. after the install the car wont start. Sometimes it does but then shuts off right away. Could the black top ones be my issue? Thanks to anyone.
Injectors need to had writen 450 on it near plug or take a multimeter and check if it have 2ohms.
When i ordered them they said they were for a 90' and were 450's. The part numbers are different though. Is that my issue? The tips in the black ones are longer than the blue ones.
i wouldnt think so what psi are you getting to the injectors. if not do a test to make sure your getting enough fuel. not sure what stock psi on fuel test though. any help? and your spark is ok i had this same thing happen then die out.
I think its 40psi. I have no tool to check untill tomorow. Whats the difference from blue and black top since there both applied for a 90'?
I ended up putting the old blue ones back in. Runs fine. The black top ones must not work for a 90' talon.
If the injectors are used its also possible that they need to be cleaned, and while you're doing that you can see what the actual flow values are on the injectors to know if they are correct for your setup or not.
If you have any other questions about that just let me know.
