90 TSI FWD
- 281
- 47
- Oct 26, 2004
Vacaville,
California
First off, I'm not sure where to put such threads at, so I put it in the Newbie forum area. If there is a better place this should have been, let me know.
I have some issues with my car, and I'm running out of ideas. For a while now, I've been have starting problems. For the past few months, my car would occasionally take a long time to start. The engine would crank and would take a while before the fuel pump kicks on and starts the car. This happened maybe four or five times between January and March. One of the times I had it towed. Another time, it started 4 hours later. The other starting attempts were fine.
Recently, my car finally decided it would not start anymore. I'm not getting any fuel pressure and my pump is not turning on. The day after it would not start, it started and ran fine. The day after that, it wouldn't start, and never started for a week. (me for a week:
) I changed the fuel pump relay and checked the connections, and everything is fine, but the fuel pump just wouldn't kick on. I decided to get another one. I put in a new Walbro 255 HP fuel pump, and changed the battery because it was dead. The car started right away, and I drove a few miles! I was happy and went home.
The following night (Friday), I was going to go home for the weekend (I go to UF, but am from Jacksonville). I go to my car, and crank it. It took a while to actually start. I figure this is because the fuel pump is still brand new..? I go to a gas station and my car dies when I pull in.
It took two tries with me holding the gas pedal for it to start. I drive straight to my apartment, shut it off, and let it cool down for an hour. I go back out to start it, but it won't start! No fuel pressure. Now I'm stumped again. I'm leading to believe that the ECU might be my next thing to try or check out. One reason is because my car does not always let me change the stock boost gauge setting (chipped eprom). It also does not run lean when I engine break, when it should. It just continues to cycle. Also, because the problem began when the Florida temperature changes were ridiculous - cold to hot to cold, etc.
Does the ECU control anything related to the fuel pump? I was thinking for a second that my AFPR may be the culprit, but what does it have to do with the pump not even turning on?
Any help is appreciated. I need a car. My apartment is without food, and I'm losing so much money eating on campus.
Thanks,
Chad
) I changed the fuel pump relay and checked the connections, and everything is fine, but the fuel pump just wouldn't kick on. I decided to get another one. I put in a new Walbro 255 HP fuel pump, and changed the battery because it was dead. The car started right away, and I drove a few miles! I was happy and went home. The following night (Friday), I was going to go home for the weekend (I go to UF, but am from Jacksonville). I go to my car, and crank it. It took a while to actually start. I figure this is because the fuel pump is still brand new..? I go to a gas station and my car dies when I pull in.
It took two tries with me holding the gas pedal for it to start. I drive straight to my apartment, shut it off, and let it cool down for an hour. I go back out to start it, but it won't start! No fuel pressure. Now I'm stumped again. I'm leading to believe that the ECU might be my next thing to try or check out. One reason is because my car does not always let me change the stock boost gauge setting (chipped eprom). It also does not run lean when I engine break, when it should. It just continues to cycle. Also, because the problem began when the Florida temperature changes were ridiculous - cold to hot to cold, etc.Does the ECU control anything related to the fuel pump? I was thinking for a second that my AFPR may be the culprit, but what does it have to do with the pump not even turning on?
Thanks,
Chad
