no spark
cody900rr
Jun 29, 2008
mt.vernon, Ohio
ok heres the deal i have a 95 gsx with a 1g 7bolt i had a hard wired cas in it i started to get a miss at cruzing speeds so i found a blacktop an switched them out then came a problem of running real lean wen under a load like uphill car would boost 10psi at 2000rpm so i switched the two signal wires on my cas and it didnt start i switched them back and all it woud do is backfire now no spark at all and i have checked everything and changed everything that has to do with the spark even the ECU and everything came from a runnin car and i checked all the fuses anybody have any ideas
id check to see if you really have spark or not first. If you ran lean with a blacktop, im guessing base timing was off. Are you sure the CAS isnt installed 180 Degrees out ?
refer to RRE Instructions if you dont know what im talking about.
i have had it apart 3 times ti check my base timing and its good im not 180 out. its not sparking a couple people told me to replace my colent temp sensor and i jus got a testlight to see if im gettin any power to my cas and coil ive done some searching there are alot of people with the same problem but they never said what fixed there car :nono: but i thank you for ## help wen i fix it ill post what it was :thumb:
