No Spark!?
vinnyy
Nov 16, 2008
oceanside, California
Im getting absolutely zero spark in all cylinders. I just had a 6 bolt swap done. The car ran fine for like 24 hours. My coil pack tested good. I have new wires. Is the power transistor the thing that is bolted on the bracket that holds the coil pack?
Yeah I believe Power transister is bolted on a bracket under the coil pack.
1. Is your ECU good?
2. Is your CAS plugged in and right?
3. Did you pull out a wire and hold it near grounded metal to see if it was sparking?
good luck :thumb:
edit- OK I checked and the "Power TR unit" is mounted right by the coil pack... I have no clue what it is :)
