No Spark Starting to think ECU since its a 95
Sounds like ecu. Same thing happened to me, I had a bad ecu. I went thru everything. Finally got another ecu, car fired right up! Best of luck:pray:
Ok Cut wire 25 and 26(crankshaft and camshaft sensor input wires) 3in from ECU moved ignition switch to run and i have 5v coming straight from the ECU. Is this a bad ecu or is there supposed to be power on this circuit when the engine is not cranking?
All this trouble and you haven't bought an ecu still? Buy a ecu for $40 from miller import parts and see what happens. Worth a shot after this long.
I have two ECUs in my garage now both were bought trying to fix this issue, with no luck. thanks for the web site though I will check it out.
