Still no spark
eclipseflybyu
Jun 16, 2009
warren, Ohio
i tried and tried to get spark but still none got a new harness and new crank sensor all plugged in grounds are all good coil and wires are new plugs are new and guess what still no spark so this is me giving up and putting my 97 eclipse rs 420a turbo for sale if i dont shatter all of the glass and burn it to the ground:banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead:
Check ECU, also check ignition system relays/switches before you give up, I bet you its something stupid as hell making it not fire. trace wires to check for wear and cracks. Dont give up yet man. check the coil as well I think you guys use an external coil dont you?
yeah switched coils jus to make sure nothing.... fuel kicks on no spark and how would i know if my relays under the hood were bad
Test them. Start at the ASD relay with a voltmeter, and check for its operation and that power is making it through it's switch. Go from there.
How to test the ASD, and testing components related to a no-spark situation has been covered several times. Search. ;)
  • Wanted 6 bolt NT water pipe
    • chrisman287
