2G no spark after repairs
RussianEclipse
38
Sep 25, 2012
Walnutport, Pennsylvania
i have a 95 eclipse gst. The problem is i have no spark. i have already just replaced the cam and crank sensors and properly retimed the engine. I still have no spark. I then replaced the fuel pump/mfi relay. still no spark. I tested the wires and plugs and they checked out. I then checked the coil. The secondary coil read 14k ohms, which is within the 11.3k-15.5k spec. The primary read 1.5 ohms, when spec is .7-.85. Do i have a bad coil? if the secondary is good, should two of the plugs spark? im not sure how it works. i have no spark on all cylinders. All help would be appreciated. also should iridium plugs be gapped?
Check out my post " 2g coil rewire" in this same forum. I had the exact same ohm reading on my secondary @ the harness 1.4 ohm. Originally the wires were frayed on the back of the coil from engine vibration. I removed the fuel rail to easily removed the coil pack. Repaired the wires with heat shrink tubing but for the same ohm reading. I rewired them one wire at a time with 10ga wire and it dropped the ohm reading to .86 exactly! Check your wires or swap them out.
