no spark after changing shifter tested everything
jbeaton9292
847
75
Aug 29, 2013
Sterling heights, Michigan
ok well i have a 90 talon i drove the car last night home from work it started first try no hesitation idled fine drove fine.
this morning i changed out my shifter base and cable because i had a 90 base and cable with a 91 trans. the change went smoothly and now the car wont start.
i have replaced the coolant temp sensor and it is not giving me a code for that so i can eliminate that problem. I changed the cas and tested to be sure it was turning over the fuel pump and poping the injectors which it is so i know that is good. Next i changed my coil with a known working coil still nothing, i also changed the ptu with a known working ptu still no spark. the plugs are new with under 1k miles on them and still look new
what gives why wont my car spark. im starting to think it just dont like me as everytime i try to fix a problem another one starts it never ends. :notgood:
