No sound.. WTF!!!
GoAt
Jul 11, 2011
Ferryville, Wisconsin
My Aftermarket radio just cut out and shut off, after i turned the car off and back on i have no sound at all but the radio turns on and i can adujust the volume and other things on the radio itseft, but i still have no sound...
Are you still using the aftermarket radio internal amp? Or the amp from the stock Infinity system? If so there is an amp under the passenger seat and that might not be getting power either a fuse or possible broken amp.
I agree double check the fuse for the amp under the seat. Only other thing is the radio shorted out. you can pull teh radio and just direct connect a speaker to the radio.
its either the radio or amp and btw when you bought the aftermarket hook up did you get one for amp or is it a regular one?
there a few ways i'm sure i just bought the jumper harness and bypassed the amp totally,or you could just run wires from headunit to each speaker indavidually..
Thats to much work. Ebay that kit is $3.00 and thats shipped.Besides you want to get the best out of your stock infinity system.
