No Power
97 GS-T
Jan 19, 2007
Somerset, New Jersey
i have a 97 gst, today i installed a hall effect cas, before i was using a optical cas. After i was donr installing the sensor and took i for a test ride i noticed that it had no power form about 1000 rpm and has no power thoughout the rpm range. could have anything to do with the injector triggers or spark. here is a link that might support my theory.
http://www.magnusmotorsports.com/tech/1gina2g.pdf
ok last night when i got home from work. i took out the spark plugs and the y were very black. the car is running very rich.
Well, for starters, your profile filled out would be awesome, so that people can get an idea of what sort of setup you have.
Are you sure you didn't install the CAS 180* out? and was the CAS known to be working/have you tested it since the install?
i fixed the problem the car needed more timming, and the plugs needed to be regaped. i had the timming set for 5* at idle so i turned it up to 10* at idle. than took it for a ride and it pulled with all the power back.
well, for starters, your profile filled out would be awesome, so that people can get an idea of what sort of setup you have
i do have my profile filled out, the car is stock except for the bolt-ons.
