No power
1blackteg
Aug 1, 2005
clovis, New Mexico
I just put my motor back in yesterday and started the break-in last night all was going well untill about 15 min. ago when all of a sudden the engine just isn't responding. It won't produce any boost, when you rev it it like it just sits there and hits a wall like an early rev-limiter almost..... it won't come out of vacume. I've already changed the plugs, checked all vacume hoses, looked around for Major boost leaks (don't have a tester so can't accually test), and checked the turbo. I'm only on about 8psi right now for the break-in. There is my mod list:
6 bolt motor:
Crower Rods
Wiseco .40 over pistons
NEW crankshaft
mitsu metal headgasket
Built head
cams - lift and duration 264/272 & adjustable cam gears
arp headstuds and rod bolts
forrester intake manifold - thing is a beast!!
950cc injectors
mustang throttle body 70mm i think
fidanza flywhell
act 2600 clutch - less than 1k on it
tranny is rebuilt with quaife lsd and galant 1st gear and double synchros
indy race core "race" intercooler and all custom made piping
garrett 60-1 .63 A/R
turbonetics exhaust manifold
blitz bov
tial 38mm wastegate
fluidyne radiator & FAL fans
3in exhaust from turbo back with brullen muffler
walboro 255lph fuel pump
steel braided fuel line from tank to fuel rail
larger fuel filter to accomodate larger fuel line
battery relocated to the trunk in sealed regulation box
no a/c & no cruise control
AEM fuel pressure regulator with gauge
electronics:
Haltech E6K
AEM wideband o2
aem intake air temp sensor
greddy boost, egt, oil pressure guages.......52mm
Sorry about the long post I just wanted to include everything so I could get some help.
Thanks for any suggestions
I would say your rich from tuning or boost leak, but you said your always in vacuum; and rich would cause an increase in boost pressure, and if you had a boost leak big enough to hold at vacuum constatly, you should be able to find it by eye.
How's your electrical situation? Maybe it was just a loose connection from install that worked it's way loose; that sounds logical, since you said the car stopped running so good after about 15 mins or so.
If I were you, I'd just double check all the electrical connections; keep us updated, and good luck. :thumb:
  • Wanted 6 bolt NT water pipe
    • chrisman287
