no power steering, how to loop the lines?
eclipse1999
99
Aug 10, 2006
new york, New York
I have a gst, with no power steering. right now, theres no pump, belt and the container. i heard if you loop the lines right at the rack, steering will be a little better. I want to know how to loop the lines. do i have to go under the car to do it? any pictures will be perfect
Just trim the metal lines back closer to the rack. Then you can take some of the original rubber line you took off and connect the two making the loop. It works a little nicer if you use part of the line that has a molded corner. I always turned the wheel a half turn in both directions to pump some of the fluid out before you make the final connection.
