No power over 3k after DP install
1SicDsm
106
Sep 21, 2005
Visalia, California
:dsm: ok ive done alot of searching and i havent quite found my problem, heres what happend i just installed a new downpipe 3inch with cat delete, then i turned my car on and ran it up and down the street and dang it was fine running strong, then like 1 hour later i was driving and i punched it a little and after hitting 3k Rpm it kinda started bogging and the boost goes up really fast but the rpms dont go anywere even if i have it at WOT the rpms just go up really slowly, also psi stays at 10 when before it was hitting 16, ive checked the intercooler piping and all is tight doesnt look like there is a leak
thanks guys, in the middle of the night i realized it might be the stock intercooler pipes so in the morning i took everything off and checked them the top IC piping i was able to remove by hand it had a crack in it so i replaced it and DAMN it made everything right again running like a champ.
MOD EDIT: Removed bench racing questions/crap.
Ask Mr. Honda to go to the track with you sometime.
I YES IT FEELS ALOT BETTER TO BE RUNNING STRONG, AS FOR THE BENCH RACING, i dont need it anymore i took him right now raced him got him 1st 2nd and in the middle of 3rd i blew a pipe off and he kinda caught up but its ok i am sure ill put 2 cars in his ivtec powered a$$ GATTA LOVE DSM POWER!!!!!!!!!:dsm:
Congrats. You beat a Honda in a drag race. It's like clubbing a baby seal with a backhoe, for the most part. For some real fun, go set yourself up (at the track) against a Camaro Z28. If you've got a real set of stones, shoot for an SS.
Nah, no need to pay out the ass for t-bolt clamps when you take the time to properly bead your IC piping. Most shops will do it fairly cheap, or you can makeshift one in place by running a bead of two-component epoxy or JB Weld around the end and letting it dry completely before reinstalling it.
Yeah you know what man, I attached it right and strong, you know whats weird the CEL is not coming on I thought sure enough after I put the cat delete downpipe it would come on does it only come ON in some cars?:dsm:
