TurboDSM90
Freelancer
- 1,192
- 50
- Aug 20, 2002
Fremont, California,
California
wow, thank you for going in depth and correcting my assumptions. Its also nice of you to going into a little more detail about your setup, for some reason honda guys keep that stuff top secret....i know, DSMrs are a close community and thats always been a plus.Originally posted by GRNDSM
>A) your compression is higher than theirs,
Not really, I am using 8.5:1 pistons which give me 175psi of compression. We were all in the same ballpark. I am also pretty sure that they both used HKS cams.
>B) your running more boost than them or spooling faster
We all had around 27-30psi. Spool-up is irrelevent whe you are speaking of top end torque.
>C) The FRH intake mani moves the powerband too much,
>and to rapidly( that one came out of my ass)
Well... my point is that FRH does NOT move the powerband enough...
>D)your turbos built differently/different brand, etc., or
We all had 60/60-1 type Garrett turbos. My turbo is ball-baring and theirs had conventional bearings, but that mainly make the difference for spool-up. Which, again, is not as important when looking at the top end.
>E)your tunning is very very very well suited to your needs, as
>it should be on every dsm.
Well, we were all around 410-420hp, so those were similarally tuned cars. My and Brian's cars both used VPC/SAFC combo, Chad used RamChargers translator.
Anyway, I was just very suprised at how quickly their torque went away once they got above 6500rpm. That does not look good to me...
I know that this is not a conclusive test, but that was a first time where I saw a drastic difference, which I can mainly atribute to the intakes.
Leon
RR
Thank you sir, and everone on this topic for posting, this has been very informative...
You're telling me.
