No more 6 bolt 2.4 cranks from MMSA :(
KJS1820
68
Mar 14, 2004
Yardley, Pennsylvania
Well part # MD080691 for making a 2.3 stroker is ineligle for ordering :( so if you can still find one get it now! since you won't be able to get them from the local Mitsu dealer! I have heard that the Hyundai crank is the same anyone have the part # I have found it may be 23110-33100 ? Will the mitsu bearings fit or are the hyundai cranks cut different?
I don’t think you can get the G4CS crank new either. I searched for a new one for 2 months before I just went out and just picked up a used short block and pried the crank was good. Turned out the crank is just fine. The rod and main bearings are the same as the 4g63.
You can use a crank from a 91 Hyundai Sonata. It's a 2.4 L crank, It's around $500. I have to find the part number for you.
while were on mitsu part numebrs, could someone give me the mitsu part number for the mls headgasket, thanks
