2G no injector pulse
CT DSM 06114
42
May 26, 2004
Hartford, Connecticut
No injector pulse
A little background; 99GSX, stock motor with fmic, gm maf-t, safc2. Car came in on a tow truck for me to look at. The shop who worked on this prior to me, did not soldered any of the connections. It was all twisted together and taped.
What I have tried so far:
Checked spark with a spark tester
Checked plugs themselves
Fuel pressure strong after the regulator
Noid checked the injector clips, failed
Do have a 12+ on all the clips, pass
No injector pulse at the ecu.
After several days of search on tuners, link, and talk, I am still not getting injector pulse.
I unplugged the maft, connected another ecu, car fired right up. I quickly shut it down. Plug the maft back in, and no pulse again.
What I changed so far since last 2 days:
Removed maft, new ecu, good ptu, good resistor pack, new cam sensor, checked clips with noid lights, and still no pulse. I would have changed the MPI relays, but they are 2 black relays, and my spare is the brass looking relay. Unless you guys know where I can find such relays.
Thanks
Tony R.
In fact remove CAS and turn it by hand with key on - injectors should fire.
That cannot be done with my cam sensor. I have the magnetic version, not the green/black top versions where you can manually spin the CAS.
Thanks
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
