jed344
Supporting VIP
- 1,515
- 563
- Jan 10, 2008
Waterville,
Iowa
ok i have a 97 gsx has 145k on it mods are listed on my page. i recently got ecm link and tuned it myself yesterday at 16psi and it was running great pullling strong and it had more left in it. So today i turned the boost up to 20psi and was tunning it on 20psi nothing went wrong no knock, lean, timing issue. just didnt like the way it was pulling so i lower boost to 16 and start again then i notice its having trouble staying running after i let off gas. Then it gets to the point were i am at now that it will idle and rev fine just when it revs down will almost die then come back and if you try to drive it it will have no power and almost choke out will blow some smoke aswell as it chugs. Ecm link isnt showing my front o2 voltage as moving just sits at 0 could that be the problem, or is it what i fear and lifted the head or popped the head gasket? Btw i returned all setting to stock just to see and didnt change a thing. Ecm link also shows throwing no codes
