no fuel to fuel rail???
Silentdriver_7
Jan 23, 2008
howell, Michigan
Just replace the fuel pump and filter in my 98 talon, and im still not getting fuel to my fuel rail and my car wont start still. Could it be the crankshaft postioning senor??? Please help
Found out the problem, it was a wire grounding out at the fuel pump, Thanks 4 everyone input to help me out
Are you getting voltage to the fuel pump? If the pump is working then take off the fuel filter and see if you get fuel coming to the filter. You can check this by turning the key to on and that should supply volts to the pump.
Check to see if your getting power to the fuel pump if so do just like the prev. message said and check the fuel filter if your still geting fuel good check the fuel rail but if not check the fpr located right above the fuel pump to see if it still working hope this helps
