no fuel ???? to the rail
95GSXCO
268
Mar 15, 2006
Sterling, Colorado
iam getting no fuel to the fuel rail its a new pump and filter. i know iam getting fuel at the line under the car but its just not getting to the rail. iam not sure but i think i might not have set the new pump in right with the o-ring and that i might be lossing all the pressure from there. i'am pretty sure i put the cap back on the tank right? any other ideas?:cry:
Not making much sense? Ok, how do you know your getting fuel under the car but not to the rail? I am assuming this is a fuel pump install? Can you hear the pump? Are you checking at the line before the rail? Please list more details if you want solutions.
Read my post That I just replied to in this thread. http://dsmtuners.com/forums/showthread.php?t=225451
i know iam getting it from under the car because i just loosen the hose to hard line and put 12 volts to the fuel pump test conn. under the hood. and when i do that i hear the fuel pump and it comes out of the line where i disconneted it. well i guess i will have to go and pull the pump and make sure that the o-ring is on there right. for some reason it just didn't feel right when i put the new pump on.:shhh: sorry just so used to the v8's.
and none of the intake piping is on but that shouldn't matter should it? these cars cant be that picky can they?
Yes they can be very picky. But yes it would at least fire. My guess is something isn't right with the install. If you hear the pump, doesn't mean its picking up but thats a start. At least you know it comes on. There shoud be a plastic seat and an oring on the end of the pump. You got it? Also if its sucking air from anywhere it won't pump.
